Voltage Fluctuation Problem
turbosi92
Post by turbosi92 »
I am having a fluctuating voltage problem on my 92 civic si with my Hondata. I have read somewhere that you can remove the ALTC wire on the ECU harness to fix this issue. Is this something you can only do on an OBD2 car? Or should I remove this wire on my OBD1 Civic?
If this is something I should do, which wire is this on the harness? :?:
You can try this and see if it helps.
The wiring diagram can be found at http://www.hondata.com/techwiringgsr.html
turbosi92
Post by turbosi92 »
Spunkster wrote:You can try this and see if it helps.
Try what?
turbosi92
Post by turbosi92 »
Try what?
Bump
Voltage control
This only is a problem on OBDII cars, but if you want you can try removing the ALTC wire from connector which plugs into the ECU to see if it helps.
turbosi92
Re: Voltage control
Post by turbosi92 »
Hondata wrote:This only is a problem on OBDII cars, but if you want you can try removing the ALTC wire from connector which plugs into the ECU to see if it helps.
Can't you just disable ELD in ROM Editor? Someone mentioned this on Honda-Tech.
turbosi92
Re: Voltage control
Post by turbosi92 »
Hondata, can you verify with me about Disabling the ELD?
Disable ELD error
Disabling the ELD error does just that - disables the error code if you don't have an ELD. Try removing the ALTC wire from the harness.
turbosi92
Re: Disable ELD error
Post by turbosi92 »
Hondata wrote:Disabling the ELD error does just that - disables the error code if you don't have an ELD. Try removing the ALTC wire from the harness.
What is ELD?
Any idea what PIN it is for the ALTC wire?
DaX
Post by DaX »
ELD = Electric Load Detector
turbosi92
Post by turbosi92 »
DaX wrote:ELD = Electric Load Detector
Thanks Dax
So which pin is the "ALTC" wire?
