DATALOG GRAPH ZOOM IN DISPLAY PROBLEM
carbonctr
Post by carbonctr »
Hi
I am having a problem each time sooming into a datalog graph. I click on the area that I want to zoom in to, then right click and select zoom in. Normally I would do this many times depending on the size of the datalog to get the desired zoom level. Most times the display stops zooming in properly and displays as in the image attached. All I can do is zoom back to full and try again.
Any ideas to what may be causing this? I have updated and reinstalled my laptop's graphics driver with no improvement. This has been occurring for at least the last 3 versions. I am currently using KManager V1.3.4.
You can now just right click and drag across the section you want to zoom in on. This makes it more precise and faster to zoom in on the desired areas.
carbonctr
Post by carbonctr »
Excellent! Some of my datalogs are very large and this will make life easier. As does the set new start and end feature.
Many thanks for your help!
