please need help
albastiki
please need help
Post by albastiki »
Hi there, actually I'm looking for base map for the following parts with B16a engine 9.3:1 compression with Ross pistons and eagle connecting rods, skunk2 intake manifold. The injectors I have are FIC 1050cc, Aeromotive Fuel Pressure Regulator, Hondata 4 bar map sensor and 3/t4 60-1/.63stage 3 garrett. thanks anyone can help me out to start the car since I have idle surge problem with big injectors. I even need the MAF calibration to run the Hondata 4 bar map sensor.
thanks......
albastiki
Garrett_si
Post by Garrett_si »
the MAP not the MAF
in parameters > map, select omin/hondata 4 bar
albastiki
Post by albastiki »
Thanks man for help, but still need a calibration to run my car.
Dos any body have a base map to run my car at around 20 to 25 psi
albastiki
Garrett_si
albastiki wrote:Thanks man for help, but still need a calibration to run my car.
don't use any calibration files for your big setup
tune it
albastiki
Post by albastiki »
thanks bro,,
but any caliration around 15 to 18 psi??? coz we i dont have any tuner in my location and i want to run my car more than 15 psi..
albastiki
cardinal811
Post by cardinal811 »
Why are you worried about the PSI factor and not the power?
Bragging rights or something?
albastiki
Post by albastiki »
cardinal811 wrote:Why are you worried about the PSI factor and not the power?
Hello
No, Sir, I am not concerned in this regard but I need to help because I do not have any qualified person to improve the car in the area where I live
albastiki
Garrett_si
all turbo setup are different
you need to tune it, and if there is nobody to tune it, you need to make it yourself
albastiki
Post by albastiki »
Thank you very much brothers for the responses, and I will try to tune my car with myself
albastiki
OTT
Post by OTT »
drop me a mail i can help you!
ek9turbo @ live.co.uk
