K-Pro Dual o2 sensor
Boofster
Post by Boofster »
Application: '06 S2000
As per instructions, I picked up a primary o2 sensor from an '04 RSX.
Just to double check, the part number was 36531-PRB-A01
Trying to install it right now and it seems the harness is about 4" shorter than the stock s2k sensor. I can't find any slack to plug it in.
What are people doing in this case? Do I need to re-solder extend the harness or is there a trick I'm missing here?
Da Boost
cranny
Post by cranny »
you can either make one if you have access to spare or parts harness's , or you can buy O2 extentions from a couple different sites.
Boofster
Post by Boofster »
cranny wrote:you can either make one if you have access to spare or parts harness's , or you can buy O2 extentions from a couple different sites.
Thanks. I'm interested in those that have already installed it.
Da Boost
cranny
Post by cranny »
lol , ok.
It will fit just fine, but you must reroute the wires over the transmission instead of around the back of it like it is when stock.
Boofster
Post by Boofster »
I popped another clip and was able to wire it reasonably well.
Fount this extension which may be exactly what we need to return to stock path:
http://www.clubrsx.com/cr/CLU-O2EXT.html
I will install and report back.
Da Boost
