prc ecu compatibility
L_S_i
Post by L_S_i »
Ive searched a litlle but i want to ask it anyway
PRC ecu plus PRB o2 sensor and PRB kal, is the right way to go or is there anything wrong with this mix?
Plus im using it on a pra ep3 ctr, and yes i know i need to do some wiring, like ive done before using prb´s ecus on it, so i guess i need to do it also in the PRC, Am i right?
To conclude it, prc is pretty much like a prb?
YEs, both the PRC and PRB have the same wiring
L_S_i
Post by L_S_i »
Spunkster wrote:YEs, both the PRC and PRB have the same wiring
Thanks, with that answer i assume your "yes" inclues all the other questions, i can use prb basemaps and prb o2 sensor, correct?
correct
