K20A JDM DC5 CALIBRATION NEEDED
Hey all,
I'm new on here and wondering can anyone help me out with a suitable calibration or near as? All help greatly appreciated,here are the mods:
K20A-R DC5 JDM ENGINE
Stock itr cams
Hytec 76mm exhaust mani
Skunk Mega Power R 70mm exhaust system mani back
RBC Intake Manifold
Hi flow CAI
K-PRO
330CC Standard Injectors
95 OCTANE PUMP GAS
Thanks in advance,
Adrian.
Stock itr cams
RBC Intake Manifold
Hi flow CAI
K-PRO
95 OCTANE PUMP GAS
Thanks in advance,
Adrian.
Sorry my bad 310 they are, already ran that map it's ok with a few tweaks but there's more in other maps so fortunately i downloaded another members 217whp map for a k20a2 with itr cams and seems to pull hard with no knocking between 2k-3k after a few tweaks. I know the compression ratios are slightly different in the 2 engines but this should'nt be too off?
andres-eh2
I have one at home I will post up tonight for a close to identical setup
jdm type-R k20a
RBC IM
Hytech Header
stock injectors
custom CAI
PrototypeRacing velocity stack
here is a comparison between my .kal & stock ITR .kal (no other changes or mods) FYI this is on a low reading dynapack - I hit 230whp on a dynojet
jdm type-R k20a
RBC IM
Hytech Header
stock injectors
custom CAI
That's brilliant mate very good figures there and a very close setup,if you can post up that calibration or pm it to me it would be great help! Many thanks6spd_ek wrote:I have one at home I will post up tonight for a close to identical setup
jdm type-R k20a
RBC IM
Hytech Header
stock injectors
custom CAI
Re: K20A JDM DC5 CALIBRATION NEEDED
hardcorersxs wrote:K-Spec98R wrote:Hey all,
Stock itr cams
RBC Intake Manifold
Hi flow CAI
K-PRO
95 OCTANE PUMP GAS
Thanks in advance,
Adrian.
Thanks mate i'll give you an e-mail if i get stuck and don't get sorted out,cheers.
Garrett_si
which diameter exhaust?6spd_ek wrote:I have one at home I will post up tonight for a close to identical setup
jdm type-R k20a
RBC IM
Hytech Header
stock injectors
custom CAI
It's 3" diameter with 76mm ex mani for the mapGarrett_si wrote:which diameter exhaust?6spd_ek wrote:I have one at home I will post up tonight for a close to identical setup
jdm type-R k20a
RBC IM
Hytech Header
stock injectors
custom CAI
Garrett_si
the graph & kal posted I had 3ft of 3" pipe off the header :shock: I think my dynojet 230whp was std not sae
later on I did add a full kteller/burns stainless 3" exh with a 24" resonator & short muffler & made the same power.
eventually (with full 3") I switched IM's to a custom IM & 70mm TB & made 227/166 (gains throughout) - its tough to say which mod the power came from so I will be doing much more testing in the near future :twisted:
NOTE the low cam is not fully tuned on my kal or in the graphs
