Maverik
Posts: 50 Joined: Fri Mar 10, 2006 12:55 pm
Post
by Maverik » Tue Apr 14, 2009 7:32 am
Hi,
It seems that sometimes the IGN value does match with the IGN value that is in the calibration file (see picture).
Any idea on what is causing this?
KManager version: 1.3.5.4
ECU: PRA
vehicle: European Civic Type R 2002
Spark plugs: NGK BKR8EIX
Ground location: as suggested by Hondata
Posts: 24356 Joined: Fri Sep 20, 2002 5:06 pm
Post
by Spunkster » Tue Apr 14, 2009 5:05 pm
Try clearing security (online, tools, clear security) and then closing the program, then reopen it and load your calibration and upload it to the ecu.
Maverik
Post
by Maverik » Sat Apr 18, 2009 12:19 pm
Spunkster wrote: Try clearing security (online, tools, clear security) and then closing the program, then reopen it and load your calibration and upload it to the ecu.
I did it, but this didn't solve the problem. Any other ideas?
[/img]
Maverik
Post
by Maverik » Tue Apr 21, 2009 6:48 am
It seems that the IGN value fluctuates more when TPS goes to zero.
Does it happen also with other ECUs like PRB, PRC?
Hondata, can you please tell me if this is something to worry about?
Posts: 10665 Joined: Thu Aug 15, 2002 12:13 pm
Post
by Hondata » Tue Apr 21, 2009 7:31 am
At idle the ignition will be anywhere from 0 to 20 degrees.
We're in the process of testing this in a vehicle.
gigaCTR
Posts: 34 Joined: Fri Apr 24, 2009 3:31 pm
Post
by gigaCTR » Sat May 16, 2009 2:45 am
i think i got some IGN issues as well
why would the ign retard (spikes) at no change of any parameter?
K20A2 with boltons
PRA Kpro
gigaCTR
Post
by gigaCTR » Wed May 27, 2009 11:51 am
any idea causing this spikes?
Post
by Hondata » Thu May 28, 2009 7:43 am
We tried the same calibration in a vehicle here, but did not see the ignition spike.
We know that a bad TPS signal causes a similar problem - the ECU thinks that there is tip in retard the whole time. I also suspect that incorrect gear ratios make the ECU think you are changing gear when you are not.
