walter
Posts: 27 Joined: Thu Mar 26, 2009 5:32 am
Post
by walter » Tue Jul 07, 2009 1:15 pm
Spunkster wrote: Are you using the stock ECU or the Group-N ECU with the FlashPro?
I'm using stock ECU. I've sold Group-N ECU, cruise control worked with Group-N ECU.
I made mistake, my stock ECU number is RSP-E02, not RSP-E03.
FN2 R-04455
mw1978
Posts: 32 Joined: Tue Dec 30, 2008 11:06 am
Post
by mw1978 » Tue Jul 07, 2009 1:23 pm
HONDATA cruise control work only on race MAP caliration but not on 6th gear. 4th,5th is fine but on 6th doesn work!!!
REV lights also doesnt work on MAP calibration
TODAY i found problem with fuel gauge, It drop 1cm after 5 miles. My car used 30L of petrol!!!
dinoc
Posts: 116 Joined: Wed May 16, 2007 4:35 am
Post
by dinoc » Tue Jul 07, 2009 1:23 pm
Also, trip computer and trip fuel consumption worked fine with the Group-N ECU.
Euro Honda Accord CL9
chris87
Posts: 7 Joined: Mon Jul 06, 2009 12:23 am
Post
by chris87 » Tue Jul 07, 2009 1:29 pm
when you will fix this Hondata ?
dinoc
Post
by dinoc » Tue Jul 07, 2009 1:45 pm
It looks like there are a lot of bugs with the FN2 calibrations ... I think I'll stick to Hondata ECU and not buy this until this are solved.
I don't understand why , the Group-N calibration does not offer the same functionalities (reported as bugs above) like the Hondata ECU Group-N did.
Posts: 10652 Joined: Thu Aug 15, 2002 12:13 pm
Post
by Hondata » Tue Jul 07, 2009 4:21 pm
The trip meter will not work with race calibrations - this is in the help file.
There is a problem with the cruise control on AFM calibrations for the Euro CTR. This has been fixed for the next release, which will be in the next day.
walter
Post
by walter » Tue Jul 07, 2009 11:06 pm
Hondata wrote: The trip meter will not work with race calibrations - this is in the help file.
Thanks Hondata :D
FN2 R-04455
chris87
Post
by chris87 » Wed Jul 08, 2009 12:54 am
Thank you Hondata !
dinoc
Post
by dinoc » Wed Jul 08, 2009 1:21 am
How about the rev lights, are this working ?
Post
by Hondata » Wed Jul 08, 2009 7:22 am
If the 'rev lights' use the dash CAN bus then chances are they will not work with the race calibration.
Please confirm that your gear ratios are:
1 3.266
2 2.13
3 1.517
4 1.147
5 0.921
6 0.738
Final 5.062
dinoc
Post
by dinoc » Wed Jul 08, 2009 1:00 pm
Yes, the gear ratios are correct.
chris87
Post
by chris87 » Thu Jul 09, 2009 12:01 am
when comes the fix ?
dinoc
Post
by dinoc » Thu Jul 09, 2009 1:11 am
There is a tuner in SIngapore who managed to have trip computer and fuel cunsumption enabled with MAP calibrations on a FN2.
If I understand correctly is Joel from drivencrazy.com.sg
So I guess this is possible to be done?
dinoc
Post
by dinoc » Thu Jul 09, 2009 10:15 am
Well I've found out they were using a MAF calibration (not MAP) that's why he managed to have everything working.
walter
Post
by walter » Tue Jul 21, 2009 3:10 pm
Cruise control works on Group N calibration, also it works on MAP calibration, except on 6th gear. Can you fix that?
FN2 R-04455
