Hondata K20A3 reflash and CEL?
Questions / support for the K-Series ECU re-flash
andy
Post by andy »
I currently have a "hi flow" catalytic converter that is causing an
emissions light/CEL. Will the Hondata ECU flash work with this?
Would it cause any problems?
It will work, but will not eliminate the error codes.
andy
Post by andy »
Spunkster wrote:It will work, but will not eliminate the error codes.
Thanks. That's fine about the codes (working on a solution to that
as we speak), but I wanted to make sure running in "open loop" wouldn't
cause the Hondata-flashed ECU to act all funky.
