part throttle tunning
allm0t0rGSR
Post by allm0t0rGSR »
i dont understand what is part throttle tunning is, is there any minimum and max percent of the TPS when pressing the gas pedal, and is it suppose to be steady or press it gently as the rpm increased?
does anyone know what is the dead time of 440cc Precision Injectors 12ohm, the guy told me from Precision its 2.63 at 13v, but it doesn't seem ryte to me....
thanks
allm0t0rGSR
i already read it but it doesn't tell if how u control your feet on the gas pedal?
crucian
Post by crucian »
If you already read it, all you got to do is go drive the car around and tune to what ever AFR you want when driving. Just keep driving and driving till you get it right. That's all it takes. It's not hard at all.
kinetics
Post by kinetics »
Just start driving, and as the load comes down, press harder on the gas to keep it where you want. Less throttle for lighter loads, more for heavier.
Alternatively, you can use your brakes to simulate load, if you don't want to continue to increase speed. Careful not to overheat them though.
