Modified Airbox + Reflash ?
Questions / support for the K-Series ECU re-flash
Akula
Post by Akula »
Hello Hondata!
My friend has modified the inside of the stock airbox fn2,
He has removed all the inner bulkheads in the airbox to create more air volume, See here the pics in attached.
Well, how works the Ecu reflash with this modification ?
Image Image
Thanks!
CTR FK2 R-03220
We have not tested this. You will have to actually try it on the dyno to see what difference if any it makes.
Akula
Post by Akula »
yep, and could cause problems to maf and map sensor this modified airbox ?
thanks for the reply :)
CTR FK2 R-03220
It may interfere with the AFM, this is not something we have tested.
