Parameters Boost control
allm0t0rGSR
Post by allm0t0rGSR »
why is my boost vs rpm vs gear is set to 0.01... but i save it like 70 each table.... can anyone tell me why it does that ?
Martian
Post by Martian »
because the highest value in your pressure vs duty cycle is 11.5. So it has no idea what 70 is and defaults the value. You need to input what psi you want in that table per gear/rpm.
thank you, thank you, I'm here all week
With V1.4.3 there are two values the boost by gear tables can contain:
- target boost (this is how previous versions worked)
- duty cycle (a new option 'Gear Based Duty Cycle').
If you want the old functionality, select 'Gear Based Target Boost'.
allm0t0rGSR
i want to use the Gear Based Duty Cycle because my psi dropped at high rpm....or this feature is no use?...
I think you just need to enter the duty values into the table. They default to 0.1% because (due to space limitations) the same table is used for both target boost and duty cycle.
allm0t0rGSR
is there anyway u can fix it with the next version? it would be great because u can run it with the same psi as the rpm increased.... thanks
What, exactly, are you trying to do, and what is not working?
allm0t0rGSR
im able to save 70 or over duty cycle on my calibration before clossing the smanager, but when i opened again it shows 0.01
You must tell us exaclty what you are doing step by step.
allm0t0rGSR
ok at boost control, i set it to normall closed at solenoid configurationm and gear base duty cycle at control method and 5 psi at activation pressure...at boost vs rpm vs gear i set it to 70 each and save and closed the smanager... but the next time i opened, it show to 0.01?
We will look into this and see if we can reproduce this.
Fixed a save/reload problem, download and isntall V1.4.4
