remote start with flashpro????
FlashPro Manager software
06_civic_si_gi
Post by 06_civic_si_gi »
I need to know if anyone has had a problems installing remote start with flashpro on there car? I have an 09 civic SI that wont remote start will that have anything to do with flashpro. :cry: thanks
The Power Of Dreams
redk20simia
Post by redk20simia »
you cant remote start without the key in the car
The FlashPro reflashes the stock ECU. It does not change any of the wiring or external behaviour of the ECU which may affect an after market remote start. If you want to eliminatethe FlashPro as a factor then upload a return to stock flash.
Sven
Post by Sven »
Running a 2205 AstroStart in my 09 Si with FlashPro. No problems at all. Who installed your remote start/what brand is it?
-Sven
09 Si Coupe
06_civic_si_gi
viper and the shop i work at..... its the 5902 hd alarm with remote start.
The Power Of Dreams
all-black
Post by all-black »
make sure the inobilizer is being de activated properly by the dei
556u or whatever device ur using sometime placment of the ring that goes around the imobilizer is touchy. also make sure the cranking time on the remote start is set long enough to start the car. also that u use voltage sense so that the remote start knows when the car has started.
maiku
Post by maiku »
Mine works fine with the remote start. I had remote start first then added flashpro. No problems.
Did the remote start ever work or did you only have it with flashpro? If it never worked then consult your installer.
