Methanol fuel and k pro
saltracer
Post by saltracer »
Can I run methanol with my k pro? Not a meth injection set up , but methanol fuel. I want to change to a fuel class with my car. If I use a plx wideband o2 sensor is this possible. The engine is a 2002 Honda s2000. Thanks
saltracer
Post by saltracer »
Anyone? Someone out there must have something to add to this. Does anyone have any experience with methanol or nitro fuel pertaining to a hondata kpro? Dos don't s advice?
The ECU can hadle it, but you may have other areas where you have problems...injector size, seals, pump ...etc.
saltracer
Post by saltracer »
Thanks spunkster, I was hoping so. I will handle the other problems as I am setting up the system.
sass
Post by sass »
:D :D
You will also need EGT sensors, because due methanol burn out candles and valves. Composition of A / F should be in throttle full 10.7. You just have to do coctail with your methanol. OIL% METANOL% GAZOLIN%.
Cr-v RD8+K24A2turbo+Kpro V4 prb+NPR3/6Speed+ТС+ HFS4 v3.2.
DynoWheel = 472kW / 589 N.m
HRX One Mile Challenge = Max Speed 282km
Known as Sniper
