FlashPro Manager software
_Mozz_
Posts: 46 Joined: Mon Nov 02, 2009 7:34 am
Post
by _Mozz_ » Mon Nov 02, 2009 7:37 am
Hi,
Cant seem to be able to ask for my Rebate, as it tell me the ECU hasnt been reflashed. But it has!!
What can i do?
Regards
Posts: 10665 Joined: Thu Aug 15, 2002 12:13 pm
Post
by Hondata » Mon Nov 02, 2009 11:21 am
Can you tell use the part number of the ECU and what reflash it has? You can use the 'send support information to hondata' function if this is easier.
_Mozz_
Post
by _Mozz_ » Tue Nov 03, 2009 10:24 am
Hi,
Yesm that is what i tried to do. I use the reflash calibration that comes with FlashPro.
Dont have ECU number here, will see later.
Regards
_Mozz_
Post
by _Mozz_ » Fri Nov 06, 2009 5:18 am
ECU Part Number:
37820-RSP-E02
Post
by Hondata » Fri Nov 06, 2009 9:05 am
Sorry, I needed the ECU part number. Use the 'send support information' function.
dinoc
Posts: 116 Joined: Wed May 16, 2007 4:35 am
Post
by dinoc » Sun Nov 08, 2009 4:47 am
I have the same problem with mine.
I have FlashPro and OEM ECU reflashed with a custom MAF calibration by CPL Racing Uk, but when I tried to use your "rebate" function it tells me the same, like the ECU is not reflashed .
What can be the problem ?
Euro Honda Accord CL9
_Mozz_
Post
by _Mozz_ » Sun Nov 08, 2009 9:54 am
Hi,
I still have the same Problem.
The message that comes up is:
"There was a problem processing your rebate request. (ECU has not been Reflashed)
Any pointers??
Regards
Paulo
_Mozz_
Post
by _Mozz_ » Mon Nov 09, 2009 10:50 am
Support information sent..
Paulo
Post
by Hondata » Mon Nov 09, 2009 11:30 am
Got the support information, but can't find your ECU in our database.
Do you know when it was reflashed, and what program was used?
_Mozz_
Post
by _Mozz_ » Mon Nov 09, 2009 11:33 am
Used the latest version, and it was on the 20th of October.
Regards
Post
by Hondata » Mon Nov 09, 2009 5:43 pm
Are you confusing a 'reflash' with 'reflashed by FlashPro'? They are two different products. Since we don't offer a reflash for the E02, I think this is the case.
_Mozz_
Post
by _Mozz_ » Tue Nov 10, 2009 7:27 am
OK,
I am using the stock ECU reflashed by Flashpro.
What do i need to do then?
_Mozz_
Post
by _Mozz_ » Tue Nov 10, 2009 9:17 am
Hi,
I Also have a Reflash ecu!! Just not using it with flashpro....!!
Do you want the number of that aswell??
Regards
Posts: 24359 Joined: Fri Sep 20, 2002 5:06 pm
Post
by Spunkster » Tue Nov 10, 2009 10:51 am
You must use the FlashPro with the reflashed ECU to get the rebate.
