Pls need help s300 sotp working
ral24
Post by ral24 »
Pls need help the s300 stop data logging the red light stop blinking and I can’t download or upload information I plug the usb out and in and star working for 1 to 2 minutes I did this 4 time and then the red light comes on and the green off and the stop working and the check engine come on and there is no code, when I do data log the s300 do not save the information, I am using resistor spark the ecu is a p28
ral24
Post by ral24 »
Pls need help with this do I need to buy a new s300 or a new ECU thnx
From Help, About, what version of software are you using?
ral24
Post by ral24 »
the version is the 1.4.4
Download the most recent version which is 1.4.4.1
Upload a fresh calibration from File, New and see if the problem goes away.
ral24
Post by ral24 »
I didi that and is not woking
newsoltsc
Post by newsoltsc »
Was this new or used when you bought it?
Has it worked before?
I'd pull the cover and check for any burn spots (maybe something fried)
-Jose
ral24
Post by ral24 »
is used It was out of a racing car and was working in the recing car all insaid is ok the car is workin but with that problem
Try it in a different vehicle and see if the problem persists.
newsoltsc
Post by newsoltsc »
ral24 wrote:is used It was out of a racing car and was working in the recing car all insaid is ok the car is workin but with that problem
What car did it come out of?
What kind of car do you have?
And what do you mean by " I am using resistor spark" ?
-Jose
ral24
Post by ral24 »
I give up with the s300 I am going to buy a AEM
the ecu was out of a civic b18c1 from a friend he whent to AEM
Mi car is a civic cupe 1993 with a B20 vtec turbo
plugs are resistor
What else has been done to the ignition system?
newsoltsc
Post by newsoltsc »
check out this post:
viewtopic.php?t=9547
Maybe this is the same case for you as well
-Jose
lowblow
s300 trouble
Post by lowblow »
How long you been runing this s300 with your motor?
Clear s300 software from your computer and reinstall s300 software see whats going on
ral24
Post by ral24 »
My engine have a MSD distibutor but I test the p28 in a stock car and have the same problem, I have an oter car with the same problem, the other car is a track car, the is S300 are arrund 2 to 3 years old in my car the s300 have 2 weeks and have this problem from the fist day I test with a other PC and have the same problem , I change all the capacitor of the ecu and still do not work
