Idle tables temp value issue
fly_n
Post by fly_n »
Been seeing this for a while & was wondering whether its just happening to me(strange that it happens on both my PC's),but nobody else seems to have noticed it & continues to use the base cals seemingly quite unaffected.
It seems all the base cals(or most ive seen) have the Staionary idle speed versus coolant temp values all screwed up. U can change them & save them ok(or i should say,i havent tried this but my cal is set correctly & holds its values at least),but it seems to have not come to anybody elses attention.
I know ive had this happen afew years ago when an Smanager update screwed my idle tables this way,when i was trying to change units to degC & my idle went to crap,so i was wondering if its just the same sort of "units" issue or its happening to everybody?
Does this table even do anything anymore?
Seems nobody is reporting low cold start idles,was even reading another thread where their cold idle seemed to still be high,but the table in their cal appears as i show below.....
Heres a shot of what i mean,notice the temp values,this is what i see when i open most of the base cals....
you have to post your calibration
fly_n
Post by fly_n »
My cal is fine Spunkster.
What im saying is all the base cals provided with Smanager are showing these lower temperature values on the stationary idle tables as u can see from the screenshot.Open one up & check for yourself(Note;the ITR cal being the first one seems ok,open the stock jdmP72 cal for example to see.)
If u dont see the altered temp values(topping out at 65degC),then it must just be me & somehow happened on both my PC's??? or it must have something to do with changing units from degF to degC or something as i noted has happened to me before long ago.
It just seems strange that nobody seems to report lower than usual warm-up rpm values or they are all using FITV's or something.
It was just something ive noted on looking into other peoples cals lately that have just started working from one of the recent base maps provided.
I thought it might help you to correct this in the base cals & stop an influx of "why my warm-up idle so low lately" type threads popping up......
fly_n
Post by fly_n »
Heres a shot of my cal if your not seeing the difference,
My cal,
One of the base cals,
Fixed for the next release.
V-Spec race development
Post by V-Spec race development »
Good find. Thanks hondata for fixing this issue.
