Pls need help s300 sotp working
lowblow
Post by lowblow »
Either p28 or s300 problem
Try to unplug s300 from p28
And solder p28 to stock ECU
Plug in stock p28 car see what hapen
Has J12 been cut on the ECU?
ral24
Post by ral24 »
J12 is cut and the p28 is working ok with out the s300
With the key in just the on position with the engine not running will it datalog?
lowblow
Post by lowblow »
Finaly
You have to test s300 in other ecu
See if working
