Immo reflash
Questions / support for the K-Series ECU re-flash
Bard
Immo reflash
Post by Bard »
According to http://www.hondata.com/immobilizer.html
Acura Technician types your car's VIN number into their desktop PC connected to Honda
The desktop PC returns a code which allows the immobilizer to be reprogrammed for your VIN number.
What VIN is typed ? From my old ECU that lies in a box now :), or from the new one reflashed that i recieved from hondata ?
And after reprogramming immo if i reinsert my old ecu back, removing hondata dual harness, will the immo work, or i should again reprogramm immo ?
Do you have a dual adapter harness? Are you using the stock ECU from your vehicle still?
Bard
Post by Bard »
Spunkster wrote:Do you have a dual adapter harness?
Yes.
Spunkster wrote:Are you using the stock ECU from your vehicle still?
No. The stock ECU is in a table box now, but it can installed back if i`ll sell a car (cause i will sell it without dual harness).
What is the serial number of the dual adapter harness?
Bard
Post by Bard »
Number on a blue box is 2608 or 7608 :)
The immobilizier was disabled by the reflash to the stock ecu and cannot be reprogrammed.
Bard
Post by Bard »
You mean at all ? But i can enable immo thrue K-manager, there is an option ... and what about http://www.hondata.com/immobilizer.html for what is this manual ???
That will not work with a dual adapter harness.
Bard
Post by Bard »
So if i understand you correctly there is no way for me to enable immo on my car ?
And what shoud i do with a flashing bulb ?
Just unplug the immobilizer in the steering column and the light will stop flashing.
Bard
Post by Bard »
O.k.
is there a way to enable immo ?
No there is not.
Bard
Post by Bard »
If i`ll have a key and the immo from that car, from wich ECU was taken to buid dual harness.
Can this help solving the situation ?
No, the immobilizer cannot be used in this setup.
