afr stays constant
Gijs
afr stays constant
Post by Gijs »
Hey,
I bought an Innovate LM-1 and yesterday I had a mecanic install it. Output on ELD pin 15.
Now once I start it up and it's heated, it always reads the same value. It doesnt change to the AFR value while driving, it just stays the same.
I used the serial cable to read AFR's and that works fine, so it's just in the Hondata that it doesn't do anything. The values are inserted into the settings in Kmanager.
Is it wired wrongly ? It's connected to the ELD wire.. Any clue what I'm doing wrong ?
Kind regards,
Gijs
Remove the two resistors from the ECU as per this thread
http://www.hondata.com/forum/viewtopic. ... 28&start=0
Was the wire that goes to the ELD cut?
Gijs
Post by Gijs »
Spunkster wrote:Was the wire that goes to the ELD cut?
Yup it was.
We're going to check tonight that everything is ok before the resistor thingie.
retroid
Post by retroid »
I have a PLX WB wired on ELD pin 15 on a PRA ECU but didn`t cut the wire that goes to the ELD. the WB seems to work ok but should I cut it?
thanks!
It must be cut
retroid
Post by retroid »
many thanks. I didn`t cut it so I think that my AFR datalog figure were not so accurate.
