AllMotorMatt
Posts: 28 Joined: Fri Feb 29, 2008 1:06 pm
Post
by AllMotorMatt » Mon Mar 22, 2010 7:27 pm
I've been playing with this tune for a bit and cannot tune properly for the motor to start up on cold starts. Normally I have to hold the throttle for about a minute then it will idle out.
Setup is Ls Vtec around 10:1 with Pro 1's and 310cc injectors. (Turbo Build)
Attached is my map, any recommendations would be appreciated!
93 DA
Ls/Vtec
S300
AllMotorMatt
Post
by AllMotorMatt » Thu Mar 25, 2010 8:00 pm
Anyone?
Anyone have a pro1 map they can upload?
93 DA
Ls/Vtec
S300
AllMotorMatt
Post
by AllMotorMatt » Fri Mar 26, 2010 8:36 am
Also, I have searched and viewed all previously posted maps which are no help to me. I will try to get a datalog up asap!
93 DA
Ls/Vtec
S300
TTR
Posts: 116 Joined: Wed Mar 31, 2004 8:48 pm
Post
by TTR » Mon Mar 29, 2010 7:27 pm
This is my map from a 13:1 LS VTEC. It starts and idles from -5 F up. Where are your cams degreed in? Let me know if it helps.
AllMotorMatt
Post
by AllMotorMatt » Tue Apr 06, 2010 8:12 pm
Ill check it out ant let you in, cams are degreed, not sure exactly to what spec.
Actually, the fuel trim tab has some settings I was looking for. I eill try those and let you know.
Thanks!
93 DA
Ls/Vtec
S300
allm0t0rGSR
Posts: 116 Joined: Tue Jun 23, 2009 10:51 pm
Post
by allm0t0rGSR » Wed Apr 07, 2010 6:57 pm
TTR wrote: This is my map from a 13:1 LS VTEC. It starts and idles from -5 F up. Where are your cams degreed in? Let me know if it helps.
is your map tune?
TTR
Post
by TTR » Tue Apr 13, 2010 8:55 pm
Its an all motor tune, never tuned with a turbo, I just posted it to help any fuel trim issues........
AllMotorMatt
Post
by AllMotorMatt » Mon Apr 19, 2010 7:59 pm
Ok so I got it figured out Put a new IAC on the car and changed some parameter values pertaining to start u as well.
93 DA
Ls/Vtec
S300
