view "missing" sensors and voltage of all sensors
hondapowaa
Post by hondapowaa »
Hello,
I'm really satisfied about avolution of the smanager.
But i think some things can be imroved.
I want to know if you think to add in the s300 the possibility to view others sensors and their position and voltage like the tdc sensor, the ckp sensor and the cyp sensor?
In lastest versions, you add possibility to set the coil charge/discharge, the moment when injector "open"(in reality the center of this event) etc.
It is possible in a soon futur to view with precision in datalog the start/end of all of this type of events?
Another question, can you add an option who authorize us to view voltage of each sensors instead theirs converted values??
(like view tps voltage instead percent/degrees)
Thank you for all response.
Alain
hondapowaa
i love read responses :) :oops:
For many of the sensors you list there is no additional information - eg TDC sensor. For voltage values, how many sensors does this make sense for - just the MAP and TPS?
hondapowaa
Hondata wrote:For many of the sensors you list there is no additional information - eg TDC sensor. For voltage values, how many sensors does
it's not possible to have any information about the tdc sensor, the cyp sensor and the ckp sensor?
The ECU uses these sensors to determine the engine speed and position. What information specifically can the ECU show about these sensors?
