AFR readout is too high
Phantom
Post by Phantom »
I have the following specs:
Chassis: '02 Civic
Motor: Stock K20A Type R
Hardware Version: 2.16
Serial Number 07758
Firmware Version: 2.02
KManager Version: 1.4.0.0
ECU: K20A Type R (ITR)
Modifications: AEM Ram air intake, Megan Racing headers, High Flow catalytic converter, DC Sports cat-back exhaust
I wanted to know why KManager's AFR readout says I'm running extremely lean. (27:1 to 33:1) The mechanic who did the work on my car stated that it's because I have an 01-04 RSX Type S O2 sensor when KManager's readouts is trying to read off of an '05+ RSX Type S O2 sensor. Is this correct? And if so, is there something I can do in KManager (a setting in the ini or a patch) to get it to read off of the sensor properly? Or do I need to change the sensor to an '05+? Thanks.
you cannot use an 05-06 sensor. You must use and 02-04 senor with K-Pro.
Phantom
Post by Phantom »
What can cause the readout to be so high, then? Do I have a bad sensor or something? I'm a little confused about this...
Phantom
Post by Phantom »
Here's all what I've got. I updated the info on my first post as well.
Chassis: '02 Civic
Serial Number 07758
As for the calibration, I only stuck with the preset PRB ITR calibration, and changed the idle speed to 800rpm, LaunchMaxSpeed to 2, and checked Fix Honda Tip In Bug. I attached the file with the info.
Is there any more information you need?
you have not posted a datalog showing the problem.
Phantom
Post by Phantom »
Sorry. Here's one of three datalogs I have. I can't seem to upload the other two because they're 5-5.5mb. Also, I attached two screen captures.
IT looks like you either have the wrong sensor, a damaged sensor, or there is a wiring problem as it does not appear to be propelry reading the wideband.
What is the part number on the side of yoru ECU?
MarkyMark203
Re: AFR readout is too high
Post by MarkyMark203 »
Did you ever figure this out? I am experiencing the same issue with my K24 eg
