injector error option?
n2boost
Post by n2boost »
What is the disable injector error option use for?
2001 Turbo GSR, BB SC61, 1000cc injectors, stock block w/block guard, arias pistons, eagle rods, p28 w/s300, LSD, Type S BOV, Tial 38mm w/g, blox manifold, 3" down pipe, Thermal 3", Zex turbo cams, AEM gears, MSD 6BTM
Some ECUs do not have the hardware for injector testing, so the error check must be disabled.
n2boost
Post by n2boost »
thanks, for the help. :D
rudebwoy
Post by rudebwoy »
which ecu does not have this?
does p28 have it? I run 1600cc injectors.
European and Asian ECUs do not have this circuitry.
n2boost
Post by n2boost »
Ok, I have a Hondata P28 for a 2001 GSR. Does the Hondata P28 has the injector error hardware? Do I disable it or or not??? :?: :?:
What is the code on the side of the ECU?
n2boost
Post by n2boost »
The numbers on the side are: P28-OBD2B H273013 H0BDIIB with pins.
