New to the forum, B16 Turbo with GSR Cams 880cc injectors
Edison
Post by Edison »
Hello, I am using a basemap which I got from this site on my car.
Setup details:
Cp pistons 9.1:1 comp
Eagle rods
Balanced and blueprinted
ACL bearings
3 angle valve job, and back cut
All new gaskest and oil pump and water pump and timing belt
Edelbrock intake manifold
880 cc injectors (precision)
AEm fuel rail
ACT 6 puck unsprung clutch
Quaife LSD
Precision SC6152E turbo
Custom made topmount amnifold
Tial wastegate 38mm, Tial BOV
PWR?
3" exhaust 3" Stainless exhaust, dynomax ultraflo Stainless muffler
the map which i was using is here:
http://www.hondata.com/forum/viewtopic.php?t=7101
the car just doesnt seem to run right; I hold the rev's and it just dropps down. I am wondering if the map is not applicable to my application, but who knows.
The only last thing is the walbro fuel pump I have is not working properly, but the fuel pressure stays consistent at 43psi.
Any help would be appreciated.
Don
You need to get the car properly tuned on the dyno.
Edison
Post by Edison »
Spunkster wrote:You need to get the car properly tuned on the dyno.
yea, but I just need someone to look through the tune. I know I will need a dyno, but driving the car there is my first priority.
Edison
Post by Edison »
ahh everything is good now :)
I just need a tune :)
yay
