kpro help needed
leetec
kpro help needed
Post by leetec »
hi noob here located in scotland. im havin a problem with openin the map for my car in k manager an error message pops up sayin
"list index out of bounds (0)" laptop hasnt been pluged into car when this was happenin but didnt think that would make much difference?
anyone had this before? thanks lee
you can turbo a VTEC........but you cant VTEC a turbo :D
Download and update KManager. If this error occurs, can you tell us when it happens? If possible, provide a screen shot as well.
leetec
Post by leetec »
the kmanager is upto date. i have come home from work ad opened the map and no error code now. why would this be? i tried to upload it to the ecu but it doesnt seem to be workin. by this i mean i have got the map clicked upload.......the little box opens up sayin uploadin.....then when the scale reaches the end box disapears..... i thought it would have been loaded but it is still runnin on the previous map that was on the ecu. any advise would be much appreciated. am i doin something wrong?
How long did it take to upload the calibration to the ECU?
leetec
Post by leetec »
Spunkster wrote:How long did it take to upload the calibration to the ECU?
it doesnt take that long........maybe around a minute. is that about right? is their meant to be a message sayin upload complete after map has been succefully uploaded?
No, there is no message when it finishes. It sounds like it is working correctly.
leetec
Post by leetec »
thats what i thought.
ok just been playin around with the kpro their and here is whats happening.
i have saved the map for my car twice the only difference between the 2 maps is 1 has launch control+dataloging enabled and the other doesnt.
map 1 has NO launch control+dataloging enabled
map 2 has launch control+dataloging enabled
when openin map 1 this is when this is when "list index out of bounds" error occurs
when i open map 2 the map opens fine and seems to upload to ecu no problem. switched ignition and car off closed k-manager. opened k-manager and tried to down load map from ecu when the error message "please check all calibration parameters for accuracy. in order to ensurethat the binary code is upto date please save the calibration and then upload to the ecu" appeared
i clicked ok and the map that came off of ecu was a previous map i put on just to get the car started.
so why would it not be loadin my map?
i tried to update the USB drivers and got an error message sayin "error updatin USB driver(error access is denied.)
im not havin much luck as you can see........i was really looking to have car at local 1/4mile in 2 days so any feed back is much appreciated. thanks lee
post the calibrations in question
leetec
Post by leetec »
Spunkster wrote:post the calibrations in question
here you are. let me know what you think.
310bhp map.kal is corrupt and you will have to just use the other calibration and make the necessary changes to it.
leetec
Post by leetec »
Spunkster wrote:310bhp map.kal is corrupt and you will have to just use the other calibration and make the necessary changes to it.
leetec
Post by leetec »
How can the 310bhp map.kal be corrupt and the map not because is a copy so surely both should be corrupt????
What is the necessary adjustment needed?? Do you know why the map would not go onto the ecu? I appreciate your help spunkster
leetec
Post by leetec »
can anyone else help? is their anyway of fixin the corrupt map?
It cannot be fixed. You will have to use the one that works and make your changes to that one.
leetec
Post by leetec »
here is a couple of datalogs i done. can anyone tell me why the car was shuttin down at 10psi of boost? i know ithey are not the greatest but its the best i can do at the moment. thanks lee
