05 tsx w/06+ camshaft
Questions / support for the K-Series ECU re-flash
bluecarbonfiber
Post by bluecarbonfiber »
I have an 05 tsx with the reflash and plan to get the 06-08 camshaft and intake manifold w/throttle body I am curious will i need my reflash redone to match the 06? or will i see the same results with my current one?
We do not offer other reflashes. There is only one reflash and it is for basic blot-ons. The reflash is not for cam changes.
bluecarbonfiber
i guess i didnt explain it properly...
is the reflash for the 04-05 tsx different then the 06 tsx reflash due to the camshaft, intake manifold, and throttle body being different?
Yes they are, but they cannot be transfered form one ECU type to another.
bluecarbonfiber
so what is a good way to get the same results since the Kpro is unavailable?
There is nothing we currently offer for what you plan to do. I would recommend waiting to do the modifications until you can tune it properly.
tommykair20
Post by tommykair20 »
does the 06 tsx engine, has the same stock vtc as the 04 tsx ??? 25 degree?
Zoro2006
Post by Zoro2006 »
tommykair20 wrote:does the 06 tsx engine, has the same stock vtc as the 04 tsx ??? 25 degree?
yes it's the same ;)
