Map locked?
Vtec6000
Map locked?
Post by Vtec6000 »
Can anyone tell me what error message you get if you try upload map off a ecu which has been "set security"?
What exactly is happening?
Vtec6000
Post by Vtec6000 »
Can't remember 100% what the message was but it said something like access violation of some module, it would read almost to the end then stop and a window would pop up saying the above. Is that the map locked?
If you're trying to download from the ECU close all windows in KManager.
Vtec6000
Post by Vtec6000 »
Yeah I had nothing open man, just launched kmanager and tried uploading. Does anyone know the exact message which appears if you try upload map from a ecu which has had security set? Also the s300 lead is same as kpro lead correct?
From Help, About, what version of software are you using?
Vtec6000
Post by Vtec6000 »
@Spunkster, its version 1.4.0.0 feb 2010....
Post the calibration you are attempting to upload. What happens if you click on New Calibration and upload one of the calibrations there?
Vtec6000
Post by Vtec6000 »
Sorry I'm probably saying this wrong what I'm trying to do is copy the map
that is currently on Ecu into kmanager so I can tweak the current map on there
IF it will not work, then your only option is to upload a new calibration to the ECU instead and overwrite whatever is in there.
Vtec6000
Post by Vtec6000 »
So its more than likely locked? By the way what is the correct base calibration to use for a jdm import DC5 integra?
