Cam angle mapping question
Mask
Post by Mask »
hi guys, i would like to know if i have for ex. 35 degrees os cam angle to which table i map, it assumes the 30 degrees or the 40??
i hope i explain myself good.
thanks
I"m not sure I understand your question, but the maps interpolate between the values in the tables.
Mask
Post by Mask »
humm...so when i change gear the rpm falls until 7000 rpm, and at 7000 rpm i have 35 degrees of vtc and i wanted to know if with 35 it assusmes the parameters of the 30 or the parameters of the 40...so it wont be good...would be better 30 or 40 right?
It interpolates between the values.
