Request: Low-High Boost Cut Feature
The Spectacle
Post by The Spectacle »
Curious if there are plans to change the hot boost cut in the protection tab to a conditions based value, based on whether low or high boost is selected in the boost control paramaters. Am I correct in saying that as it stands right now, whatever psi you have for high boost cut is universal no matter which table you're in (high or low)?
That is correct. There is no plan to change this.
The Spectacle
Can you guys look into it? Seems simple enough to implement. Would make it very convenient to have a low/high boost switch wired in without having to have a laptop to change the boost cut when switching boost levels
