No fuel pump prime when turn the key on help plz
burmese434
Post by burmese434 »
Just started tonight. I go and turn the key on the cel comes on and goes right back off. I don't hear the fuel pump prime nd the car don't start. It cranks but don't start.. After i tried to start I'll here the fuel pump contently run and won't shut off.. I tried to check the codes but they disappeared?
burmese434
burmese434
still looking need car for work tomorrow and the car has a resistor box and 450's I wonder if it some how fried the ecu? still connects to smanager
Try the ECU in a known good car. If the problem persists then you probably have a damaged ECU and will need to replace the ECU. The s300 is probably ok.
burmese434
For some odd reason the hondata just didn't like that tune nomore?? I've used that tune for about a month now and never any problems but it's all good now
