RPM Indexes in Knock control tables
FlashPro Manager software
Gernby
Post by Gernby »
I noticed that the RPM indexes are not editable for Knock Retard and Knock Sensitivity, and are always the same as the stock calibration even if I move my indexes around for fuel and ignition. Does this mean that this table does NOT follow the indexes from the fuel and ignition tables? I've moved my indexes all around, so I want to make sure that my knock control is going to work as expected.
'06 NFR S2000
The knock sensitivity and retard tables use different indexes from the fuel & ignition. The indexes are not editable because they are used by the ECU for other tables, and editing the indexes would require all dependent tables to be adjusted for the index change.
Gernby
Post by Gernby »
Sounds good! Thanks!
'06 NFR S2000
