re-flash hondata immobilizer
beppe
Post by beppe »
hi sorry for write in a bad section....
if an hondata reflash are activated immobilizer.....only work in that car
if i put the reflash in another car how i can to work?
thanks
Do you have a reflash or the FlashPro?
With the FlashPro you uninstall if from one vehicle and transfer it to another vehicle. The immobilizer is not affected.
beppe
Post by beppe »
reflash
by default the immobilizer is disabled.....but if enable it follow the car and don't work with any other car
right?
You cannot enable and disable the immobilizer with a reflash.
beppe
Post by beppe »
i can use the reflash in another type r without problem?
If the immobilizer is disabled then it will work in any vehicle.
beppe
Post by beppe »
thanks
if i enable immobilizer in my car....the control module work only in my car
if i mount in another car is possible to re-unlock immobilizer?
Spunkster wrote:You cannot enable and disable the immobilizer with a reflash.
