done research still cant find wideband problems
brutal_redrum
Post by brutal_redrum »
im running a hondata ecu and s300 and i cant get my wideband to read in the program... analog2 shows e243 at all times using pin d6... i need help asap thank you...
brutal_redrum
Re: done research still cant find wideband problems
running b18c with forged internals and arps top to bottom other then that its stock
You need to provide details such as how you have it hooked up, brand of wideband...etc. Also calibrations and datalogs showing the problem would help.
brutal_redrum
Sorry I'm new to this and have never used hondata... its an aem ugeo... wired into b6 on a hondata ecu... I'll try to get my calibration up as soon as possible... its my friends car I'm just helping him tune it
burmese434
Post by burmese434 »
Could you use the eld d10 pin? Make sure your using the white wire coming off the gauge. Also disable the eld in the parameters.
