rpm issues
B18builder
rpm issues
Post by B18builder »
Hello. I need help. my engine will not rev past 3000 rpm once there is load. just installed the S200. but the engine revs fine w/ stock ecu. can someone help me out. thanks. appreciate it
What error codes are you getting?
B18builder
there are no codes.
Is the check engine light on?
DaX
Post by DaX »
Are you able to build boost at all? Do you have Datalogging?
Sounds like it could be limp mode due to ROM improperly installed or bad solder connections. Or it could be boost cut set extremely low [like 1psi].
