error message
VTiSpec
error message
Post by VTiSpec »
When i tried to datalogged a run i got this message on the screen and SManager also froze. I tried couple of times and no success.
TheWickedOne1
Re: error message
Post by TheWickedOne1 »
VTiSpec wrote:When i tried to datalogged a run i got this message on the screen and SManager also froze. I tried couple of times and no success.
It looks like you have two instances of Smanager up when u attempted to datalog, try again with just one instance up and report back
V-Spec race development
Re: error message
Post by V-Spec race development »
Yes, it looks like you had opened the 2 smanager at the same time.
VTiSpec
Re: error message
Post by VTiSpec »
sample you see is from a datalog file posted at the forum, which I click and the message popped out. I could not snapshot my own. I'm using a file from the forum and as it can be seen now it is only one SManager open.
Luke
Re: error message
Post by Luke »
in the error message it says: "devision by zero"
since a division by zero isn't definated mathymaticaly there is this error, i would say.
a cake given to nobody isn't pretty clever... communism style... everything "available", but nobody can get it :D
i would say, that this file is corrupted. can you upload it, so we can test it on our machines.
best regards Lukas (who lives in germany, but knows the communism from poland :D )
VTiSpec
Re: error message
Post by VTiSpec »
I can not datalog, everytime I hit F9 this message comes up and my laptop freeze. I show somebody's file that I found in the forum to show my problem. I download SManager beta and it does it since with previous version I was able to datalog. could it be configuration?
VTiSpec
Re: error message
Post by VTiSpec »
removed Beta and install 1.4.8.0 version and I'm able to open datalog file. shame I can not use beta version.
Re: error message
Have you considered sending us the datalog which is causing the problem?
VTiSpec
Re: error message
Post by VTiSpec »
I downloaded beta version, hooked to the car, I did the tunning guide steps, everything went smooth. car responded to fuel trimming changes. when I decided to get a datalog I hit F9, message popped out. tried again by clicking red dot with mouse and it happened again. everytime software freeze. in other words, I can not get a datalog.
like I mentioned previously, going thru the forum I found this datalog file and when I opened it happened again. I was able to produce this problem with it and posted it.
reinstalled old version and opened the file and I was able to see it and no message. tomorrow I will check if I can datalog. let you know.
