TPS, Immobilizer
NiTRO
TPS, Immobilizer
Post by NiTRO »
Hi!
First of all i've uploaded new calibration, checked TPS range and tried to start.
But my car wont start, TPS still in -1% and the green light in the dash flashes the whole time.
I've swapped ECU with my friend's - TPS display works well. I haven't started car on another ecu. Whats going on???
Re: TPS, Immobiliser
Do you have the immobilizer disabled? Are you getting fuel at the injectors? Are you getting spark? Have you tried the ECU in a known good vehicle?
NiTRO
Post by NiTRO »
the immobilizer disabled, fuel at the injectors and everything is well with another ECU too - it works in my friends car
ECU is PRA
Re: TPS, Immobilizer
What vehicle is this in? What is the K-Pro serial number on the K-Pro board inside the ECU?
NiTRO
Post by NiTRO »
EP3 type r
05005825
maybe i can clear all settings and try again or... is it hardware malfunction?
Go to Online, Tools and click on Clear Security. When that finishes, close the program, reopen it then go to New Calibration and start with a fresh base calibration and upload that to the ECU.
NiTRO
Post by NiTRO »
it works! thank you
