Lotus Multiplexer on PRA ecu?
Muu
Post by Muu »
Hi
Noticed in a later version of the software there is support for driving Lotus clocks via the multiplexer out. Any more info on this?
My car is a UK lotus elise, with a PRA ecu and loom. Swapping to later clocks with the higher rev counter and 3 shift lights could be a nice upgrade.
T
Re: Lotus Multiplexer on PRA ecu?
The option is only for PRB ECUs. You need a converter box. It only has been tested with the US 05-07 and US 08+ dash.
Muu
Post by Muu »
Ah shame, is that a limitation of the PRA ecu?
Would have thought the majority of swapped cars aren't fed elises as I am not aware of kits for them?
The PRA ECU does not have any room left for modifications.
Muu
Post by Muu »
AH fair enough
