B20VTEC Engine Jerks/cuts out on Full throttle/load **HELP**
iv73ci
Post by iv73ci »
Hi,
ive got a B20VTEC into an 99 EM1 civic coupe / Si.
Engine specs:
PR3 ITR Head
Stock ITR Ports
Omni 68mm TB
Supertech valve train - springs and retainers. Stock ITR valves
Works Engineering Fuel Rail with RC 440cc injectors.
OEM Fuel pressure regulator
CNC combustion cambers
Rocket M22x Cams
11.3:1 Compression
Bottom End
RS Machine 84.5mm pistons
H-beam Forged Rods
Fully balanced bottom end
Bolt-ons
Big tube 4-2-1 headers
2.5inch exhaust system
Hondata S300 P06
tuned on E85 fuel. 147fwkw (v1 tune)
Recent engine conversion from one car to another. Was working fine in the previous car (DC2) without any issues. just remove engine and fit and minor fine tuning
Once the engine has been installed in my EM1/Si the problem starts.
Basically, when you sudden give the car a full throttle/load launch on below 3000rpm on 1st or 2nd gears the engine accelerates then cuts off/jerks then continues .. it happens day or night conditions and only happens when your on low RPM and give it a sudden full throttle.
We have replaced to another OEM TPS and still failed. MAP sensor is OEM.. the TPS has been set to 0.5v closed and open 4.5v stock and values changed in the Smanager.
Rev limiter is set at 8500rpm
Vtec engagement is @ 5500rpm
My tuner has changed values for the TPS in Smanager and problem is still there.
The TB is a 68mm Omni and has been working fine in the previous car donor.
What could this problem be?
Fuel pump delivery?
MAP Sensor?
Faulty TPS?
***UPDATED***
Calibration attached.
but no datalog :(
Re: B20VTEC Engine Jerks/cuts out on Full throttle/load **HE
iv73ci
Post by iv73ci »
Ill get the calibration and datalog frm my tuner.
iv73ci
Post by iv73ci »
Calibration now attached!!
Please HELP!!!
need the datalog showing the problem
iv73ci
Post by iv73ci »
Spunkster wrote:need the datalog showing the problem
Dammit.
My tuner doesnt save datalog.
I have to pay him just for a power run to obtain a datalog :(
Any other way round it?
datalog yourself
iv73ci
Post by iv73ci »
Spunkster wrote:datalog yourself
How??
Plug in laptop to hondata and go for a test drive??
Do i need to turn on datalog in smanager?
If so where?
Do i need smanager online to datalog? Or can i datalog without having the laptop plugged in? Ten download the log after?
Connect your laptop and datalog directly and make a recording of the problem then save it. You do not need to turn on on-board datalogging.
iv73ci
Post by iv73ci »
Sorted the problem out.
Turns out the TPS needed a replacement.
All sorted.
