Need CAL for K20Z1
KnightX
Need CAL for K20Z1
Post by KnightX »
hey guys I have a K20Z1 in my EG with Kpro.
over the winter I've put on a set of TWM 52mm ITBs onto the car, the car now has no MAP sensor and is using the TPS sensor.. I need to change from MAP to Alph-N on my kpro
my question is does anyone have a basemap for this setup so I can start up the car?
the car will be tuned by Turtle very shortly by turtle but I would like to get a map so I'm able to start her up so it saves a little time on the dyno..
thanks!
Re: Need CAL for K20Z1
You need a working MAP sensor, even if it is alpha-N.
KnightX
Post by KnightX »
well I do have a MAP sensor on the car plugged in but its just sitting off to the side cause the ITBs only have a slot for the TPS
It needs to read manifold vacuum.
mkulak
Post by mkulak »
I thought Turtle was in Hong Kong now?
Need a Kpro or s300 Tuned in the Toronto area? Send me a PM.
