K24a2 swap on RSX type s with kpro ac not working
accountant
Post by accountant »
Hi Hondata,
I have K24A2 from TSX swap into 02 Type S RSX.
I'm currently running TSX 04 stock base map
Multiplexer= normal
Immobilizer= disabled
No other changes were made on the parameters.
My problem my AC/Heater stop working.
There are on going MIL on after driving.
I'm a noob and I'm not sure how to attach my datalogging. I hope, I attached it correctly.
ECU #37820 PRB A05
2068-500117
Kpro #2068-401173-OI19
Purchased from Authorized Hondata Dealer Church Automotive January 2012
Please help. Thank you
Re: K24a2 swap on RSX type s with kpro ac not working
Calibration? What error code do you get?
accountant
Calibration = Stock 2004- 2005 TSX dual adapter. Stock K24A2 , 310 cc injector 91 octane fuel.
Error codes
heated catalyst not supported
second air system not supported
ac refrigerant not supported
EGR not supported
ac blow warm air. Heater seems to work now. It blows hot air but not as hot before the swap tho..
Why are you using the dual adapter calibration? You should use the RSX calibration. Also, those are readiness codes, not error codes.
accountant
well, I have consulted a few people with k24a2 swap on an rsx including the rsx driver that was featured in hoda tuning and hybrid racing that told me that i should use the tsx calibration not the rsx?
