Fuel Increment (Control + I) bug
FlashPro Manager software
VitViper
Post by VitViper »
FPM version: 1.2.8, happens in all calibrations using speed density fueling tables (AFM or straight MAP), doesn't matter what ECU or what car.
As I've started working more and more on E85 tunes or very large injectors I've noticed that using Control + I to increment the fuel value (whether whole column/row selected or a single cell) it maxes out at 32000 and will not increment past that. However using Control + J and using a percent value works just fine to go beyond this "32000 boundary". Very annoying when I'm rescaling fuel tables...
All my computers are Windows 7 64-bit.
b.r.i.a.n.
Re: Fuel Increment (Control + I) bug
Post by b.r.i.a.n. »
why not just use the overall fuel trim? i know hondata has infinite resolution but the overall fuel trim would make it a lot quicker to rescale everything for e85.
2003 Civic Si - 241 whp/166 tq - all motor - sold
2002 S2000 - 234 whp/155 tq - e85 powered :D
2006 TSX - daily driver
I've changed the maximum.
VitViper
Post by VitViper »
b.r.i.a.n. wrote:why not just use the overall fuel trim? i know hondata has infinite resolution but the overall fuel trim would make it a lot quicker to rescale everything for e85.
That is a poor method of rescaling a map for E85 as it won't be a blanket 30% (or w/e) fuel unit change across the whole map. However, my issue isn't about rescaling a map for E85 to begin with.
Hondata wrote:I've changed the maximum.
Thank you.
