FlashPro Manager software
Posts: 10652 Joined: Thu Aug 15, 2002 12:13 pm
Post
by Hondata » Wed May 09, 2012 1:39 pm
2009-2010 TSX Support
Quickspool
Holds the wastegate shut until just below the target boost to spool the turbo quicker.
V1.3.0 Changes
FlashPro firmware updated to version 45
Added support for the 2009-2010 TSX.
Added long term fuel trim min/max to closed loop parameters.
Changed Check For Updates to show current version number and release dates for both beta and production releases.
Added quick spool to boost control.
V1.3.1 Changes
Fixed Conversion exception when checking for updates with non-English language settings
V1.3.2 Changes
[S2000] Added minimum ignition timing tables.
V1.3.3 Changes
[Civic Si / CTR] Added VTC deceleration angle control.
[Civic Si / CTR] Added gear ratio correction for ECU gear detection as well as cruise control.
[Civic Si] Added boost cut, fuel overrun cut delay, second ECT sensor, VTC cam angle index.
[Civic CTR - Euro] Increased maximum cam angle to 50 degrees, added warm up retard table.
[S2000] Changed P2A00 error threshold.
mabo
Posts: 64 Joined: Sun Mar 18, 2012 2:21 pm
Post
by mabo » Thu May 10, 2012 2:13 am
Very RAW release.
First, i still see 1.3.0 on top after i installed 1.3.1,
it constantly shows error
It still show 1.3.0 in check for updates and after i press download 1.3.1 it throws error - update.exe isnt win application.
IcEMoCHa
Posts: 61 Joined: Fri Oct 01, 2010 8:00 am
Post
by IcEMoCHa » Thu May 10, 2012 4:21 am
Unable to open any calibrations using this version.
VaporBomb
Posts: 2 Joined: Thu May 10, 2012 10:31 am
Post
by VaporBomb » Thu May 10, 2012 10:43 am
I am getting the same error. I also cannot open any cals. This was my first install, and I have uninstalled it. Should I try to reinstall v1.3.1, or is it ok to just download v1.2.8?
Thanks for any help.
Posts: 24145 Joined: Fri Sep 20, 2002 5:06 pm
Post
by Spunkster » Thu May 10, 2012 3:35 pm
It has been fixed. Try it now.
VaporBomb
Post
by VaporBomb » Thu May 10, 2012 5:49 pm
Spunkster wrote: It has been fixed. Try it now.
Seems fine now.
mabo
Post
by mabo » Fri May 11, 2012 9:55 am
Works fine , thanks guys. Please dont pull out old one before you see new one is working )
beaugus
Posts: 35 Joined: Wed Dec 08, 2010 12:20 am
Post
by beaugus » Sat May 12, 2012 4:03 am
In regards to the recent addition of "Added long term fuel trim min/max to closed loop parameters" - does this adjustment allow us to virtually "disable" long and short term fuel trimming on MAF/MAP hybrid calibrations by making the values "0" and if so are there any significant concerns by doing this?
My FN2 is running a hybrid MAF/MAP tune at the moment and the fuel tuning is virtually flawless but the short and long term fuel trimming is affecting my tune the longer I drive and have been waiting for the option to disable fuel trimming and hoping this new option finally allows me to do this.
Just wanted to be 100% sure before I commit to making changes to my tune that I'm correct in saying that changing the values to 0 will esentially disable short/long fuel trim whilst in closed loop.
mabo
Post
by mabo » Sat May 12, 2012 5:51 am
mabo
Post
by mabo » Thu Jun 14, 2012 10:22 am
i had 1.3.1 on second PC , selected check for updates option , pressed download 1.3.2 ang got this
Not shure latest build have this error but i cant check it )
Post
by Hondata » Fri Jun 15, 2012 9:19 am
Anti virus software is removing the update.
mabo
Post
by mabo » Sat Jun 16, 2012 2:58 pm
Sorry but its not an a-virus tricks. Its system error, before i posted i tried it on clean VM and disabled antivirus on regular system and got same error.
Post
by Hondata » Sun Jun 17, 2012 6:52 am
Then use explorer to check the update.exe file in your User directory, and see if the file runs directly.
Post
by Spunkster » Mon Jun 18, 2012 10:41 am
Try downloading the update directly from the downloads section of our website.
mabo
Post
by mabo » Sun Jul 08, 2012 1:49 am
Hondata wrote: Then use explorer to check the update.exe file in your User directory, and see if the file runs directly.
I tried , this file is zero length ( 0 bytes ) and i cant open it, same error. I disabled a-virus and reinstalled manager , same result.
