Smanager and Win7 64bit issues - FTDI strikes again!
shiroitenshi
Post by shiroitenshi »
Getting this problem after I updated to 2.0.0 SManager
Stop 0x000008E in usbport.sys
Doing this does not help as it cannot remove the driver entirely.
http://www.hondata.com/techre4ftdiupdate.html
Updated to 2.1.1 results in different error Stop 0x000007E
Works fine in XP, so it's likely a driver issue.
Re: Smanager and Win7 64bit issues - FTDI strikes again!
The RE4 fix was specific to the RE4 cable, and will not help here. Also, we've used the same FTDI drivers since 2009, so upgrading versions should not make any difference.
The assumption always has been in Windows that newer versions of a program are always better, and they will get installed and overwrite any previous versions. For applications, this makes sense, but for shared drivers there is no advantage to upgrading the driver if everything is working correctly. The problem we've found is that other hardware devices also use the FTDI drivers, and can overwrite the FTDI USB drivers with a newer version. In theory this is all fine and well, but FTDI drivers are not always backwards compatible, and/or have bugs, which is what the RE4 cable problem was caused by. I contacted FTDI about this but they would not fix the bug. A compounding problem is that Windows does not fully uninstall a USB driver when you uninstall it. Also it may be difficult to track down what other hardware devices use the same drivers.
Here's what I suggest: These all assume a certain level of PC know how.
Open the device manager, find the s300 USB device, and open the properties. The driver version should be 2.4.6.0 and the date should be 3/13/2008, otherwise it has been updated. Post what you see here.
Uninstall the drivers method #1. Create an environment variable devmgr_show_nonpresent_devices=1 from System Properties -> Advanced -> Environment Variables. Open the device manager, under View select 'Show Hidden Devices'. Under the USB controllers rich click and uninstall all the S300 / KPro etc devices. On Windows 7, select the 'uninstall driver' option too.
Uninstall the drivers method #2. Download and install the RE4 fix from http://hondata.com/updates/FTDIUSBFixSetup.exe. After installation, from the start menu run (as administrator) the 'FTDI Driver Clean' application. After is has run, uninstall the RE4 fix.
Uninstall the drivers method #3. Under Windows/Inf do a search for oem*.inf containing Hondata. Delete the .inf files and the .pnf file of the same base name.
Uninstall the drivers method #4. Under Windows/System32/Drivers delete FTD2XX.sys and ftdibus.sys files.
Reboot, make sure only the latest version of SManager is installed, then connect the s300. When prompted, don't allow Windows to look online and direct it to the SManager installation directory.
Hope this makes sense. Good luck.
shiroitenshi
Thanks, I do have the required pc know how to do the above. I'll try it out and post the results here.
shiroitenshi
Well, thanks to your input, I've gotten the version out at least. apparently it appears to be an earlier version? Either that or the versions number are revised.
Anyway, I think this is related to a Labview software I installed in between the pre-SManager 2.0.0 which updated/changed the ftdi drivers without me knowing.
[Version]
Signature="$Windows NT$"
DriverPackageType=PlugAndPlay
DriverPackageDisplayName=%DESC%
Class=Ports
ClassGUID={4d36e978-e325-11ce-bfc1-08002be10318}
Provider=%FTDI%
CatalogFile=ftdiport.cat
DriverVer=04/10/2012,2.08.24
[Version]
Class=USB
ClassGUID={36fc9e60-c465-11cf-8056-444553540000}
Provider=%FTDI%
CatalogFile=ftdibus.cat
Proceeding to uninstall drivers and hope this solves the problem.
shiroitenshi
http://hondata.com/updates/FTDIUSBFixSetup.exe couldn't remove all the registry entries even when running with administrator priviledges, I'm not sure why, because browsing the registry via regedit still lists the registry keys as being present.
Looks like I might have to hunt them down individually.
Life was much simpler in Windows XP, the safeguards restricted permissions in W7 to prevent end users from muddling the registry is a bother.
If this doesn't work, looks like I'm going to run multi OS setup after this.
Seems like you have made some progress tracking down the cause.
Using devmgr_show_nonpresent_devices=1 should allow you to remove the entries from the device manager, which should then delete the registry keys.
