PLX Wideband wont connect with S300
Steeve_Civic
Re: PLX Wideband wont connect with S300
Post by Steeve_Civic »
OK, I read several times this page and instructions, but still don't understand, sorry.
Moreover, What do I need to connect a wideband to a ELD?
ELD =PIN D10= Electrical load??
Is there the good setup on this?
What is the correct Voltage with a PLX?
Last edited by Steeve_Civic on Fri Nov 16, 2012 12:23 pm, edited 2 times in total.
Steeve_Civic
Perhaps, I need to switch my wire from D14 Pin to D10 pin??
Steeve_Civic
I re-checked yesterday and it seems to work now.
My wire were correctly connected to ELD PIN D10 but on S300 the AF (in options - Sensor) was in lambda unit not in Air fuel Ratio.
I needded to put 1,99 voltage Offset to read the correct value
Hope it helps someone else.
