Help! Relay wiring for IAB (Secoundary Butterfly) (-)output!
gherrera
Post by gherrera »
Good day everybody,
This is the question that never end, I know but I can't found a reliable way of wiring the IAB solenoid.
I have a P28 with S300, first try I follow the wiring diagram of VTEC relay for non-vtec ECU, thinking it works as same with the IAB solenoid, but never works with this setup.
Then I follow the troubleshooting guide of Service manual for the IAB system, I turn the Ignition ON and check for voltage between Pink and the Black/Yellow wire, I found any voltage but the relay activated well, after that I checked the voltage between pink and chassis I found voltage then did the same with black/yellow and Surprice!, also found voltage there.
Reading the service manual, the pink wire must be a negative output, well the tradicional way to wire relays as negative outpu did not work because the trigger is a negative output (PIN A15 ACC (Air Condition Cluth) from ECU.
My wiring for the relay is;
The first try as VTEC diagram; 85 = A15 ACC Output , 86 and 30 = positive ACC , 87 the pink wire to wiring harness.
The second try, tradicional Negative output; 87 and 86 = chassis ground , 85 = A15 ACC output , 30 to the pink one
Really apreciate someone help me to wire the right way.
saludos from Panama!
Re: Help! Relay wiring for IAB (Secoundary Butterfly) (-)out
What year vehicle is the engine from?
gherrera
Post by gherrera »
Spunkster wrote:What year vehicle is the engine from?
Prelude 92 96 H22A OBD1! (FYI... I did try the Invert IAB output, but nothing happen, the relay is working well I checked it, I think is somthing about the relay wiring for the (-) output)
thanks for u replay!
You will have ot check the hemls manual for that year engine as some years the secondaries are ground activated and other years they are power activated.
gherrera
Post by gherrera »
Spunkster wrote:You will have ot check the hemls manual for that year engine as some years the secondaries are ground activated and other years they are power activated.
Right, IAB´s Prelude over 97 OBD2 are powered by (+) output
for 92 96 are (-) output
