NEED help with wideband analog input, all i see in volts
racepak
Post by racepak »
hello
yesterday i connected the white wire on my aem WB to the S300 analog input connection on the S300 board, so i could view/datalog afrs,
then i went to the smanager analog inputs and in the convertion table i choose aem 30-4100. changes the units to AFR, uploaded the cal started the car and all i can see is volts, not actual AFR's
how can i fix this?
thanks
Re: NEED help with wideband analog input, all i see in volts
From Help, About, what version of software are you using?
Please post your calibraiton and a datalog showing the problem.
