What is this?
mndc5
What is this?
Post by mndc5 »
Any help would be great
having a weird hiccup randomly while driving, durring all loads.
happened after i ran the car with out the ecu grounded properly.
i made 2 data logs
once again, any help would be great.
2005 RSX_S
Re: What is this?
The MAP sensor reading is all over the place, so it is either the MAP sensor or the 5V volt output from the ECU to run the MAP sensor. Try swapping out the MAP sensor first.
mndc5
Re: What is this?
Post by mndc5 »
ok ill try
why wouldn't the faults show up
P0106 Manifold Absolute Pressure (MAP) Sensor Range/Performance Problem
P0107 Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage
P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
2005 RSX_S
