k24 Accord block w/ RSX-S head swap
cstyleaccord
Post by cstyleaccord »
i have an accord with k24 engine and i'm planning to do a head swap with teh RSX type S head. Then i'm planning to run it with the rsx ecu and hondata k-pro...since hondata will not be able to tap into the accord ecu...does any of you guy know if it will work or any information of how about doing it....and also planning to turbo-kit it as well...
ashstudly
Post by ashstudly »
Have you received any information on this? I'm interested in doing the same thing.
You will be able to do this once the K-Pro for the 05 RSX is realesed using the adpter cable and specially modified 02-04 ecu. Your guages will however no longer function.
