s300 problem
b16turbocivic
s300 problem
Post by b16turbocivic »
hi
i just started having a problem with my hondata recently!
i had my car sitting out a my friend house for this winter, and had it stored for the two winters before. i started my car up two weeks ago and it started fine and ran great. A week later i tried to start it adn ran perfect for 50 seconds, then it started running crappy. so i hooked up my computer and pulled the tune off the ecu and it was all scrambled idle was at 300 and everything was off. so i got my other tune and loaded it on. Ran great again so i turned it off and came back the next day, to drive it home. tryed starting it and did the same thing so i pulled out the ecu and tryed loading up the good tune again but for some reson the tune would run the car for 50 second now and then die. when it was doing this there would be a redlight on the ecu until i loaded up the tune then it would go green until the car dies and go back to red! it seems like every time i turn off the key the ecu earases the new tune thats uploaded or it goes back to the scrambled tune.
Re: s300 problem
What is the serial number of the s300 board inside the ECU? From Help, About, what version of software are you using?
b16turbocivic
Re: s300 problem
the serial# s300-12,295 and im using the newist software on the site
Re: s300 problem
send and email to support <at> hondata.com with the following and I will issue an RMA and give you further
instructions (include a link to this thread):
Name:
Address:
Phone:
Email:
Serial#:
Description of problem:
